1958-1968:la domination
je vais d'abord citer Franco Lombardi ici
https://www.ferrarichat.com/forum/threa ... ne.358379/
Talking of the Maserati V8 engines, let me add that from the Tipo 54 (450S) Maserati developed the Tipo 59 (5657cc) and finally the Tipo 62 (6458cc) for marine use. Both units and particularly the last one were highly successful, transforming the KD 800kg (and later KD 900kg) racing boats Formula almost in a single-marque championship, winning every World, European and Italian title from 1958/59 until 1968 or so.
With the Maserati engines, Liborio Guidotti, Ermanno Marchisio, Spagnoli, Crivelli and Nando DellOrto, shared the laurels in those years, mostly through the Count Agusta and the Guidotti teams. Even DellOrto, after having competed with his well-known Timossi-Ferrari racer motorized by a 375 supercharged engine, after having won the Gran Premio del Vittoriale, switched to Maserati, being unable to compete with the more powerful and reliable Tipo 62.
The castings and overall architecture of those engines is absolutely the same, making easily possible to use any Maserati V8 racing engine both on sports cars and on the racing boats.
Power was officially declared at 520bhp at 7000rpm for the Tipo 59 and 580bhp at 6200rpm for the Tipo 62 (6.4-litre). Italian horsepower were rather optimistic here. Steve Griswold reckoned that the 6.4-litre unit fitted to Peter Kaus 450S (4506?) in the early 80 was probably good for 450/480bhp at the real wheel, with more to come, if necessary. More then enough in any case and more then the chassis/drive train/brakes can properly handle.
I can fully confirm the point as the engine fitted to my car, the 450S prototype, ex 350S (originally No. 3501 with Moss-Jenkinson at the 1956 Mille Miglia and then sent at the Swedish GP in August with the V8 engine), is a marine unit Tipo 62 (No. 4519) I bought in 1982 while restoring my car with the help of the factory from Count Agusta.
In order to avoid cavitations of the propellers the marine units are fitted with a smoother cam making the car easier to use: a bit like having a big-block Chevy. My car, with its modern clutch, could almost start in second, but obviously it is not made for being used like that: after all it does have a 1st gear good for 130km/h!
Nevertheless, having been fully sorted (not for competitive racing!) it is actually a relatively easy car to use on the road and in moderate track use: it does not overheat in traffic and it can be used for road rallies with great pleasure. A quick blast from time to time does remind you (and any other car in the neighborhood) that this was the ultimate weapon in its time.
Using its full performance is a different story: First of all, you should know how to drive it. Lets not forget that the Tipo 54 was not conceived for being used by private drivers, but for the works champions: Fangio, Moss and Behra. Then you need to be brave, as it keeps pulling your shoulders against the seat like a jet at take-off in any gear and it does build up speed rather quickly.
Moreover, the car is totally useless on a short, twisty track. Only at Monza you start thinking it is on its own ground and, nevertheless, the horrible variante that has emasculated the main straight is there to remind you that while you should pull it in fifth you are approaching a sort of wall that might be handled at decent speed by modern ground effect cars but that compels you to downshift merciless trying to bring the car at a safe speed to negotiate it.
Even in today ultra fast 30 miles historic races, properly set up and properly driven, these powerful monsters can still show their qualities. Thomes Bscher has impressed the crowd and it fellow competitors quite a few times to prove the point.
In any case, as already mentioned in this trend, their performances were far superior to the chassis/drive train/brakes contemporary technology.
Finally, it might be worth remembering that in the 1957 racing season, they never stopped with engine failures but for minor stupid reasons or for drive train failures. When they lasted, they were usually giving 2sec per lap to their archrival: the equally fabulous Ferrari 315/335S.
Bringing the power to the ground was and is the real difficulty. With the enormous torque delivered by my marine unit, I had two major gearbox failures. I ended up having the original transaxle redesigned and rebuilt with modern state-of-the-art CAD technologies, modern materials and 2/100mm tolerances. We have made 4 new units (3 of them are now in the States) and I feel the car is now safe.
I wish I could tell you that I am fully exploiting the car potential, but I am probably using just a limited part of its potential. Nevertheless it is great fun to drive such a great piece of history.
En résumé, le V8 Maserati est un monstre de puissance et de couple, peut être trop, les vibrations et son énorme couple mettent le reste de la machine à rude épreuve, c'est peut être pour celà que la saison 1957 du championnat du monde des voitures de sport fut perdu de peu, le V8 Maserati était peut être trop puissant.
En motonautisme en revanche, si le moteur de l'Alfetta 159 ou le V12 Ferrari furent parfois utilisé, c'est le V8 Maserati qui dominera entièrement la catégorie. Les quelques "motoscafo" équipé en Ferrari sont hyper bien documentés et les photos (magnifiques sont nombreuses), mais la vaste majorité de la catégorie reine ( KD 800 kg ouis KD 900 kg) de 58 à la fin des 60s seront avec les V8 tipo 54, 59 (5.6L) et 62 (6.4L).
Lino Spagnoli, Flavio et GIogio Guidotti vont remporter les titre consécutivement entre 59 et 61 dans la catégorie des 800 kg
de 1962 à 1969 ou la classe passe à 900 kg c'est 8 titres consécutif avec Ermanno Marchisio, Liborio Guidotti, et Gian Luigi Crivelli.
au total 11 titres consécutif pour une domination sans partage
Je pense qu'on peut tous s'accorder sur l'esthétique de ces engins, ils sont sublimes
Ici Liborio Guidotti avec le Timossi 8 qu'il utilisera de 59 à 62 et son monstrueux V8 de 6.4 l
C'est par le site three pointy hydroplane qu'on trouve le plus de documentation sur le net (et la seule en fait )
Dell Orto équippera d'abord son bateau du V12 Ferrari avant de passer au V8 Maserati
cici en 1959
Flavio Guidotti sur son Timossi 2
ici survolant les flots sur son Timossi "El Biso III"
Le Timossi KD13 a quelques photo car vendu chez RM Sothebys en 2013 (les photos RM sont de Darrin Schnabel)
Il fut utilisé par Carlo Casalini, Lino Spagnoli, et Gianluigi Crivelli, qui remporta le championnat du monde en 1969.
https://www.rmsothebys.com/en/auctions/ ... ane/293828
![Image](https://rmsothebys-cache.azureedge.net/d/f/b/8/2/5/dfb825095be7b2c29a998acf28a6e1f329aa7407.jpg)
la photo du moteur :
plus d'information ici
https://www.threepointhydroplanes.it/mo ... m55_en.htm
François. Quattroporte III
